Tire size 76 targa
Hello, i have a 1976 targa with15x 7"fuchs, i think came from a 1982 but not sure.my question is what size tires are people running with the 7" alloys? Rite now it is set to stock height but i would like to set it to euro height soon.thanks
I would suggest 205/60-15s for a relatively easy fit. What is on there now?
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
My tire size currently is 215/60/15. The profile seams thick to me. Just curious what others are running as i am looking at new tires. Thanks
76 911S Targa
I run 205/60/15 on all four wheels. You can run 215 on the rear to put a little extra rubber on the road.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Speaking about extra rubber, I'm running 215 70 15 rear (87 Carrera) and 205 65 15s up front on 6&7" cookies and it's never handled better.
Fixed it for ya.
![]() Quote:
These are All-Season sizes and not sticky summer compounds, right? Do we know what he's looking for?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 01-27-2017 at 10:47 AM.. |
Thanks for correcting the photo! I am going to be replacing my tires and was curious on what size tire others are running especially the profile (45,50,60,70) . My car is mainly normal use no track or racing. Thank you
Registered Minimalist
Since you are running midyear flares you have to double check the flare size people are offering tire sizes for> A lot don't realize the SC and later flares are bigger. So called narrow body cars from that era still can run much bigger tires.
I ran 205/50 all around on 15X7 cookies. It allows you to get incredibly low without rubbing. I thought a 205/55 would be a good match as it would fill out the wheel well more and you can still go fairly low and not rub in the rear. In my experience it's a balance between ride height, suspension stiffness, camber, rolled or not fenders, and your weight. That will dictate your tire size. I would run a 205/60 if I wanted it to look stock, and a 205/55 for more aggressive look.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 01-27-2017 at 12:32 PM.. |
Tire size 76 targa
Subscribed...... working on a suspension refresh and height n tire adjustment too.
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 |
