need help w/driver's side door
This is a pic of my driver's side door.
I noticed when I open it, it swings all the way to 90 degrees with no friction or stop points. I went to investigate and came across this.
Anyone have any guesses as to what's going on here? Would like to get everyone's input as to what happened, and how to fix this correctly.
1987 Porsche 911 Carrera Coupe
Old 01-30-2017, 06:27 AM
Looks like you need a door stop and door stop repair kit. It basically puts a plate inside of door to receive new door stop. Yours looks pretty torn up, and previously repaired with washers, etc. Parts are available from host. You will need to pull the door card to get at the inside repair. While in there lube and tighten other things you see.
Good luck.Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 01-30-2017, 07:05 AM
MBAtarga's Avatar
Lots of thread's on this topic - do just do a search:
Door stay repair without gut opening and welding
Door stop replacement.
Door Stay Reinforcement Help
Mark
'83 SC Targa - since 5/5/2001
Old 01-30-2017, 07:45 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 check inside, most likely the rubber stop inside is a goner too.
'85 Carrera Targa
PCA/POC
Old 01-30-2017, 08:19 AM
Originally Posted by MBAtarga View Post
I couldn't come up with the right wording for what it was... I searched, and searched, and searched. Finally decided to post it and realized I should of searched "door stop". LOL!!
Thanks for your links!!
Old 01-30-2017, 12:42 PM
