Please identify this battery maintainer connection
I purchased this Carerra with a battery maintainer hardwired, according to the Porsche dealership invoices that came with the car.. I am assuming this connection is it.
1. What maintainer on the market has this type of cigarette lighter connection? Did the PO do this to use one of those cigarette lighter chargers?
2. Should I just remove it and hardwire a battery tender brand?
Thanks in advance.
Old 02-04-2017, 04:55 AM
I have a Porsche branded tender that just plugs into the cigarette lighter socket in the dash. Similar I guess.
Old 02-04-2017, 05:13 AM
Barrpete's Avatar
Battery Tender brand sells a cigarette lighter adapter:
Cigarette Lighter Adaptor
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 02-04-2017, 05:58 AM
I had this option as well... but it never made sense to me.
How on earth would I be keeping my battery charged if I'm using the battery to charge itself??
And the lighter can only draw so much power to charge the battery, so if there is something else drawing power from your battery, it simply couldn't keep up?
1987 Porsche 911 Carrera Coupe
Old 02-04-2017, 06:32 AM
Thanks guys. I ordered the adapter Barrpete mentioned but from amazon.
Old 02-04-2017, 07:35 AM
Are you sure that isn't a powerlet socket? I used them on my BMW motorcycle and it had the two tab internal connector.
Powerlet Products - Rugged power outlets, cables and electronics
Regular cigarette lighter is thumb size, powerlet is pinky size if that helps?
Old 02-04-2017, 07:41 AM
Platinum Member
dad911's Avatar
For what it's worth, I really like the Anderson Power pole connectors. Rugged, and available in different sizes/current ratings. https://powerwerx.com/anderson-power-powerpole-sb-connectors
Old 02-04-2017, 07:56 AM
sky1jord's Avatar
I don't think it's a "battery maintainer" in the normal sense.
I think that that might be a socket in which to plug a low-power battery that will keep the memories/settings of on-board appliances (think RADIO presets) from losing their data if and when the main battery is disconnected for maintenance purposes.
Old 02-04-2017, 02:12 PM
