-   -   Do my RSR Struts need strut spacer and O-ring (http://forums.pelicanparts.com/porsche-911-technical-forum/945218-do-my-rsr-struts-need-strut-spacer-o-ring.html)
jimtweet 02-08-2017 03:50 AM
I am putting front suspension together and struggling with this...
I see this part:
http://forums.pelicanparts.com/uploa...1486554211.jpg
and the O ring"
http://forums.pelicanparts.com/uploa...1486554386.jpg
Here is pic of my strut, I do not see a grove for the O ring and not sure if the RSR strut uses the spacer?
http://forums.pelicanparts.com/uploa...1486554624.JPG
proffighter 02-08-2017 05:03 AM
There is no groove, but space on the backside of the bearing race (what you called spacer) for the o-ring
KTL 02-08-2017 08:16 AM
Agreed with Roland. The o-ring just packs the space between the radius of the spacer and the radius of the spindle. it's there to help reduce the migration of oil along the spindle when the grease thins or separates.
The spacer is technically not a bearing race. I think it's actually a collar that definitely provides the sealing surface for the grease seal and I believe it also serves as a stop or thrust for the inner race of the wheel bearing?
proffighter 02-08-2017 01:06 PM
Correct, it's the race spacer, see here no.39. Shaft seal is no. 21 (which seals on spacer):
http://forums.pelicanparts.com/uploa...1486587468.jpg
