Do my RSR Struts need strut spacer and O-ring
I am putting front suspension together and struggling with this...
I see this part: ![]() and the O ring" ![]() Here is pic of my strut, I do not see a grove for the O ring and not sure if the RSR strut uses the spacer? |
There is no groove, but space on the backside of the bearing race (what you called spacer) for the o-ring
Roland 930 Turbo '81 Too many modifications to list |
Schleprock
The spacer is technically not a bearing race. I think it's actually a collar that definitely provides the sealing surface for the grease seal and I believe it also serves as a stop or thrust for the inner race of the wheel bearing?
Kevin L '86 Carrera "Larry" |
Roland 930 Turbo '81 Too many modifications to list Last edited by proffighter; 02-08-2017 at 01:08 PM.. |
