-   -   915 shifter linkage play after replacing bushing, video attached (http://forums.pelicanparts.com/porsche-911-technical-forum/945385-915-shifter-linkage-play-after-replacing-bushing-video-attached.html)
KTL 02-10-2017 08:33 AM
The amount of "slop" in the factory bushings is said to accommodate some drivetrain movement (from the rubber engine & trans mounts flexing) and that slop in the shift linkage prevents the drivetrain movement from pulling the transmission out of gear.
