Stull69 (guest)
Guest
Posts: n/a
In regards to the Porsche 912 push button door handle, the linkage on the inside of the door catches when opening with the interior handle but does not catch when pushing the button from the outside. Can you direct me to the replacement parts that I should be looking for.
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Door Handle Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 02-09-2017, 09:23 AM
You'll need to remove the exterior door handle and check to see what is broken. These are pretty solid, and I think what you might find is that the lever the push button pushes is sticky and will not let the push button engage, OR an issue with the lock mechanism. Better for you to check before I offer a parts kit.
- Casey
