Factory reference points missing?
I found this diagram here on Pelican that was scanned from a factory manual.
http://forums.pelicanparts.com/uploa...1486684655.JPG I want to use a tram guage to check and compare the G dimension, but i can't find the rear holes. http://forums.pelicanparts.com/uploa...1486684922.JPG This is a picture of the left rear where the hole should be. The chassis is a 1974 911S. What am I missing? There are a few smaller 1/4" drain holes in the vicinity. Thanks, Tom |
I'm doing this exact same job and was looking for my, erm, "G-spot" the other day. This is a 1976 911S and I found plastic bungs in those corner positions of the floor pan. When I pulled the plug, the holes were threaded, as below.
Looking at the workshop manual, it looks like these points were only introduced in 1975. http://i1244.photobucket.com/albums/...psrunhvobo.jpg |
Thank you Ferrino, that explains why they aren't there. I will use the trans mount holes instead.
Thanks, Tom |
| All times are GMT -8. The time now is 07:37 PM. |
