harness abrasion.
![]() Should I be addressing this abrasion and open insulation ?
1979 SC 1986 Carrera 3.6 L+ |
Chain fence eating turbo
Well of course, silly! It can start a fire.
Diss Member
I highly recommend 3M's Scotch #27 or #69 Glass Cloth Electrical Tape. The glass fiber tape is exceedingly resistant to abrasion and general abusive handling.
It is a bit pricey but I keep a couple rolls around for a number of various uses.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Tippy/Quick,
I Should have clarified my question: The pic above shows the ground lead with the separated wire strands and squished lead insulation, That being the case, a fire risk is low , and yes re-insulating with quality tape is a must. In addition, does it make sense to clean that area up and use electrical solder over it since the individual strands have separated? How much of an impact on the wire's ability to flow current and dissipate heat has occurred by the individual wire separation, as seen above?
Out of curiosity, what harness is it and on what was it abrading?
The Harness is from my 86 carrera with a 97 3.6 varioram ITB/ECU transplant.
Noticed the harness issue during a teardown, so I won't know what it was rubbing against till re assy.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Mb,
thanks ,I did not consider possible mechanical /stress issue due to a solder joint . That would haunt me everyone I fire it up.
