French Import
zippy_gg's Avatar
Can't get passenger seat out! Help!
I am stuck! I removed all 4 bolts on the back from the rail, and the one on the front right, but when I try to move the seat back to get to the left front bolt it gets stuck in the forward position, moving just an inch back when I pull the lever. I checked under the seat and the lever actually does its job and releases the rail. But still the seat won't move back. I think it hits the head of the remaining screw although it shouldn't.
The car is an 86 cab, and the passenger seat is manual while the driver seat is electric.
This is keeping me from replacing my worn out and dirty carpet and recovering the seats!
I am open to suggestions. Thanks!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 06-14-2010, 07:25 PM
nineball's Avatar
try sitting in the seat and moving it back with your weight. i would put the other front bolt back in to hold it in place first.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 06-14-2010, 07:29 PM
French Import
zippy_gg's Avatar
Thanks Nineball, I tried that and no go!
Actually I could not put the front bolt back on since the seat won't move back, but I put a bolt back on the right rear. I can feel the seat hit something on the left rail and getting stuck. Arghhhh!
I'll try adding the rear right bolt back on and give it a go...
Edit: No go with bolts back on in the back! It made no difference whatsoever, the seat is stuck in the front-most position and only moves back less than 1 inch when I pull the lever. It does not move at all if I don't pull the lever so I know that part works.
What could be getting in the way? Is there another manner in which the seat can be removed?
Gilles & Kathy
Old 06-14-2010, 07:51 PM
Kaliv's Avatar
My seats out at the moment, so I'll take a look to see if I can see something obvious. But I do recall that you can pull the lever some and one rail will move...but not the other. You have to ensure that you are pulling the level all the way up to make sure both rails are disengaged.
Another thought is perhaps loose change? I know I had some seat issues a few years back...and it happened to be a few coins lodged in the mechanism.
-= Kaliv Farstryder =-
'87 Porsche 911
Old 06-14-2010, 08:13 PM
Kaliv's Avatar
Ok, took a quick look at my seat. The body of the car doesn't have anything in the way unless of course there might be a wire getting in the way. Even though my seat is mechanical...I still have a wire that has nothing to plug into.
Second issue I can think of is that there are a few hex bolts that hold the rails to the seat. If one was rattled loose, it would be low enough to jam the mechanism.
'87 Porsche 911
Old 06-14-2010, 08:20 PM
French Import
zippy_gg's Avatar
Thanks Kaliv! I already found a few loose pennies, but still no joy.
I flashed some light but still can't see any evident interference from anything, but I can definitely feel it.
I'll try again tomorrow after work.
Gilles & Kathy
Old 06-14-2010, 08:23 PM
kbruz's Avatar
The two rails move independently once they are unbolted... at least that is what I recall. My guess is that the lever arm is not fully retracting and one of the rails is not moving.
kb
mercedes GLK350
2009 boxster s
86 targa
Old 06-14-2010, 08:45 PM
I sent you a pm before I read your thread, but STILL say the same thing. I always remove the front bolts first, then I can slide the seat far enough forward to remove the rear. Put in a rear on each side and then see if you can slide it back enough to get the front bolts out, Then the Rear!! Yes it is Frustrating, but how else could you understand the word "EASY"??
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 06-14-2010, 09:05 PM
Too late, but even tho Bentley says take the rears out first (I think), you have to take the fronts out first.
Can you put a couple of the rears in and see if you can move it?
Old 06-14-2010, 09:38 PM
nineball's Avatar
83SC seat removal
might help.
Old 06-14-2010, 09:49 PM
Originally Posted by nineball View Post
83SC seat removal
might help.
He also showed that he had to remove the front Bolts so you can remove the rear. I use a very small 10 MM Socket and bar to readh the rear bolts when the front are in because you cannot tighten the rear and have the front line up!
Old 06-15-2010, 08:28 AM
French Import
zippy_gg's Avatar
The rails are indepenedant of each other, and I checked and the lever arm is fully retracting. In fact I can move the seat one notch forward and backward wile pulling the lever, and the seat is locked if I don't.
I am afraid my issue is elsewhere...
Gilles & Kathy
Old 06-15-2010, 10:49 AM
French Import
zippy_gg's Avatar
I did that last night, and still no go. The seat only move one notch to the most forward position and one position backward until it hits something, most likely the bolt head or maybe the L-shaped bracket found on the front bolts.
I forgot to mention that I had to drill 2 of the back bolts as the heads stripped before I could remove them. That was why I had the seat in the forward position...
Gilles & Kathy
Old 06-15-2010, 10:54 AM
You are having Waay too much fun!!
Old 06-15-2010, 02:19 PM
French Import
zippy_gg's Avatar
Oh yeah? Then I have to put in the new carpet from Apbiz, and then get my seats recovered, and then while I am there... LOL
Gilles & Kathy
Old 06-15-2010, 03:57 PM
nineball's Avatar
while you are in there..... i have enough damplifier pro left over to do another 911 interior if you are interested. shoot me a pm.
Old 06-15-2010, 04:21 PM
French Import
zippy_gg's Avatar
PM sent!
Gilles & Kathy
Old 06-15-2010, 04:51 PM
OK, I give! What is "Damplifier pro"??
Old 06-22-2010, 11:33 AM
At the track = great day
ChkbookMechanic's Avatar
It is a sound deadening material like Dynamat.
Damplifier Pro - Automotive Sound Deadener CLD Vibration damping mat - See what all the fuss is about
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 06-22-2010, 01:42 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Did you get the front L brackets (2) out?
And the rear seat block?
When re-installing, replace the allen head cap screws
with the correct Porsche P/N, as these are hardened,
and shallow head, for slider clearance.
And,
Don't forget the anti-seize........
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-22-2010, 02:02 PM
