Widest wheel on a stock 77 S?
Wonder my what people have run for wheel widths.
Old 02-15-2017, 09:34 PM
The common thought is a 205 will fit... 205 would rub on my driver side when cornering. Some brands didn't though. I got sick of it and just used 195s no issues now.
Rutager West
Old 02-16-2017, 02:21 AM
Bill Verburg's Avatar
Factory- 6ET36 x15 x4
factory race/rally- 6ET36 x15 front & 7ET49 x15 w/ 7-10mm spacer depending on the tire used and chassis setup or 7x15ET23.3 front & 7ET23.3 to ET41 rear again depending on tire and setup
Some private owners have squeezed 7ET23 front and 8ET23.3 rear in 15 or 16, this is a tough fitment
Bill Verburg
Old 02-16-2017, 05:12 AM
this is a 7.5" wheel with 225 tire on my '77. No rubbing with rolled lip and some negative camber.
Old 02-16-2017, 05:28 AM
Registered Minimalist
75 911s's Avatar
^Obscene that looks killer
On mine currenlty:
205/50 all around on 16X7" Fuchs
Old pic with bigger rear tires:
205/55 rear and 205/50 front 16X7" Fuchs
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 02-16-2017, 06:46 AM
Location: behind the redwood curtain, (humboldt county) california
Stock 6 inch Fuchs, height and alignment.
On my dad's very stock 74 narrow body, I had 205/60 rubbing on the right rear fender, (not the lip).
It had not yet blistered the paint, so I went with a 195/50 Dunlop.
After refreshing the rear suspension and brakes, cornerweighting and alignment, I could find some rims with a little more - offset and width.
chris
Old 02-16-2017, 07:41 AM
When I had mine, I ran 7x15 and 8x15 with 225/50 in front and 245/45 in rear. Also 7x17 and 9x17 with 225/50 and 255/40.
You can get away with sizes like that if you have...
-a stiffer suspension,
-and/or run a little negative camber (like say -1.5),
-and/or roll your fender a little.
The other trick is to closely examine the brand's exact overall diameter and section width. Ride height makes a difference too, the lower you go the trickier it gets.
'66 912 - Polo Red;
'74 911s - Silver Carrera RS clone
'77 911s - Peru red IROC Clone
'89 964 C4 - Guards red
Old 02-16-2017, 09:52 AM
that's a good point. I've found that bridgestone re-11 are super wide compared to other tires of the same size
Old 02-17-2017, 05:42 AM
I'd love to see some pics of 9x17 w/ 255/40 on a stock '77 911
Bill Verburg
Old 02-17-2017, 07:34 AM
Ingo posted some pics of his n/b w/ 944 8x16ET23.3 & 225/50 x16 tires
You can see them here
Bill Verburg
Old 02-17-2017, 07:54 AM
kent olsen's Avatar
Fuchs, Fuchs, Fuchs, been there not going back. 15 X 7 Superlitesl, 205X15 Yoko Advan
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 02-17-2017, 09:14 AM
My dad had purple. Cool color.
Old 02-17-2017, 09:18 PM
