help identifying a part
cleaning out the tunnel on a 72T and found what appears to be a nylon type of channel. it is deteriorated but it looks like some type of spacer,, i could not locate on any of the parts schematics. Any help is appreciated.
1975 911S Targa Silver Anniversary Edition |
Looks like the bush for the throttle linkage rod that runs through the tunnel. No. 13 on the PET.
81SC Coupe Tony Kart/Yamaha |
Or the idle control plastic on the accelerator line, long ago broke down.
Under the handle between the seats. Bruce |
Registered Minimalist
They are both right- they appear to be chunks of both the hand throttle valve lever and the middle throttle cable bush the other two bushes are located 1. Under the shifter and 2. Under the rear access panel where you are likely to find more chunks. Replace all 4 pieces now while you have easy access.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
yep. PP # 901-424-317-00-M100
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 02-19-2017 at 11:43 AM.. |
hi
thanks for the responses, i think it is the throttle rod link.. i would never have guess it, as it looks like a part that should be metal.
