-   -   Anyone want to rent me their trailing arm bushing removal tool? (http://forums.pelicanparts.com/porsche-911-technical-forum/946682-anyone-want-rent-me-their-trailing-arm-bushing-removal-tool.html)
1979-930 02-19-2017 07:55 PM
So you paid $100+ for that tool you used one time. How about I send you $40.00 for rental and one way shipping. I use it for one day and send it back. You recoup some of that $110 and I save a few bucks.
Hay, it never hurts to ask. :D
dondarnell 02-19-2017 09:24 PM
I torched em out.
DRACO A5OG 02-19-2017 10:37 PM
+1 torch, neighbors will hate you
911tracker85 02-20-2017 06:03 AM
I did not know there was such a tool.
matt930s 02-20-2017 06:30 AM
Torch...then buy pieces at lowes to reinstall...
MattR
matt930s 02-20-2017 06:44 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/709310-control-arm-bushing-install-made-easy.html
1979-930 02-20-2017 07:11 AM
Thanks for the link. That will help.
I was talking about the rear trailing arm tool so I didn't need to drop the rear all the way down. Elephant makes it.
Porsche Rubber Bushing Tools & Video: How To Remove Trailing Arm Bushings On Porsche 911, 912, 930
"Split Bushing Removal Tool
This clever tool is a real time saver that makes easy work of removing split bushings. Do the job with the arms still on the car, and save time and labor."
http://forums.pelicanparts.com/uploa...1487603452.png
boyt911sc 02-20-2017 07:11 AM
Trailing arm rubber bushings removal......
MattR
Matt,
I just removed the trailing arms rubber bushings a few mins. ago using a screw driver to pry the rubbers out. Maybe you meant the control arms bushings (?).
http://forums.pelicanparts.com/uploa...1487603328.jpg
To remove the remaining metal sleeves would require some grinding or heat. This for the rear aluminum trailing arms.
Tony
1979-930 02-20-2017 07:14 AM
^^^ Those are the sleeves the tool pulls out. It gets them out without having to remove the entire arm. I was hoping someone else spent the $120 and I could rent it. I will just have to pull the entire arm.
matt930s 02-20-2017 07:15 AM
Tony- I did. Thanks for the reply.
MattR
matt930s 02-20-2017 07:19 AM
Makes senses Deez. Better than using the hacksaw method I've heard others use...
donporfi 02-20-2017 11:46 AM
Probably one of these bearing pullers could be used.
You wanted to spend about $60 for renting the tool.
16PC BEARING PULLER BLIND HOLE SLIDE HAMMER PILOT INTERNAL EXTRACTOR REMOVAL | eBay
pmax 02-20-2017 12:36 PM
Neat.
Don't have the tools but if you do buy a set, I'm interested in a "rental" program too :D
when the time comes for the upgrade !
1979-930 02-20-2017 12:55 PM
^^^Dang, I was hoping you had it since you're the closest.
1979-930 02-21-2017 07:49 AM
Yesterday I was looking at the tool and thought. I'll just make one. So last night I took some measurements and drew up a sketch. I came into work today and grabbed some left over cutting edge stock, traced it out and cut one. I spent a little time grinding it into final shape and flat filed the final edge to grab the bushing sleeve. I still need to drill and tap for the spreader nut. I have about and hour and ten minuets into it.
Rough cut sketch
http://forums.pelicanparts.com/uploa...1487692073.jpg
Hot off the torch
http://forums.pelicanparts.com/uploa...1487692087.jpg
Semi-Final grind and file
http://forums.pelicanparts.com/uploa...1487692100.jpg
I'll final fit at home and let you know if it worked.
911tracker85 02-21-2017 01:00 PM
hmmm... after beating on it for a while, realized I have air tools.:eek:
I just used an air hammer on both of mine. only created a couple very small nicks that easily filed out. only took a couple minutes.
after pulling one trailing arm, I did the other in the car.
http://forums.pelicanparts.com/uploa...1487710720.jpg
hcoles 02-21-2017 05:28 PM
I'd like to rent the tools also - anyone have them around the San Jose area?
Can pay in beer or cash.
Rawknees'Turbo 02-21-2017 05:50 PM
Deez, can't you just gnaw the bushings out wiff yer toofs?!?!
Shaun @ Tru6 02-21-2017 06:25 PM
Those metal sleeves pop right out if you weld a bead inside each one.
1979-930 02-21-2017 07:41 PM
^^^ Or make a sweet tool that works.
https://uploads.tapatalk-cdn.com/201...85e8c003bd.jpg
