Anyone want to rent me their trailing arm bushing removal tool?
So you paid $100+ for that tool you used one time. How about I send you $40.00 for rental and one way shipping. I use it for one day and send it back. You recoup some of that $110 and I save a few bucks.
Hay, it never hurts to ask.
Derrick |
darnellsgarage
I torched em out.
don |
Member 911 Anonymous
+1 torch, neighbors will hate you
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I did not know there was such a tool.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
War Vet
Torch...then buy pieces at lowes to reinstall...
MattR
Dr. Phatt |
War Vet
Dr. Phatt |
Thanks for the link. That will help.
I was talking about the rear trailing arm tool so I didn't need to drop the rear all the way down. Elephant makes it. Porsche Rubber Bushing Tools & Video: How To Remove Trailing Arm Bushings On Porsche 911, 912, 930 "Split Bushing Removal Tool This clever tool is a real time saver that makes easy work of removing split bushings. Do the job with the arms still on the car, and save time and labor."
Derrick |
Trailing arm rubber bushings removal......
Matt, I just removed the trailing arms rubber bushings a few mins. ago using a screw driver to pry the rubbers out. Maybe you meant the control arms bushings (?). ![]() To remove the remaining metal sleeves would require some grinding or heat. This for the rear aluminum trailing arms. Tony |
^^^ Those are the sleeves the tool pulls out. It gets them out without having to remove the entire arm. I was hoping someone else spent the $120 and I could rent it. I will just have to pull the entire arm.
Derrick |
War Vet
Tony- I did. Thanks for the reply.
MattR
Dr. Phatt |
War Vet
Makes senses Deez. Better than using the hacksaw method I've heard others use...
Dr. Phatt |
Probably one of these bearing pullers could be used.
You wanted to spend about $60 for renting the tool. |
Still here
Don't have the tools but if you do buy a set, I'm interested in a "rental" program too ![]() when the time comes for the upgrade ! |
^^^Dang, I was hoping you had it since you're the closest.
Derrick |
Yesterday I was looking at the tool and thought. I'll just make one. So last night I took some measurements and drew up a sketch. I came into work today and grabbed some left over cutting edge stock, traced it out and cut one. I spent a little time grinding it into final shape and flat filed the final edge to grab the bushing sleeve. I still need to drill and tap for the spreader nut. I have about and hour and ten minuets into it.
Rough cut sketch ![]() Hot off the torch ![]() Semi-Final grind and file ![]() I'll final fit at home and let you know if it worked.
Derrick |
hmmm... after beating on it for a while, realized I have air tools.
![]() I just used an air hammer on both of mine. only created a couple very small nicks that easily filed out. only took a couple minutes. after pulling one trailing arm, I did the other in the car.
I'd like to rent the tools also - anyone have them around the San Jose area?
Can pay in beer or cash.
Sold: 1989 3.2 coupe, 112k miles |
Mighty Meatlocker Turbo
Deez, can't you just gnaw the bushings out wiff yer toofs?!?!
Those metal sleeves pop right out if you weld a bead inside each one.
Tru6 Restoration & Design |
^^^ Or make a sweet tool that works.
![]() Sent from my iPhone using Tapatalk
Derrick |
