Rtrorkt's Avatar
3.2L Power
Took my clone out today for a bit of run. Had not been out for 3 to 4 weeks. Always great to get behind the wheel and have at it.
Trouble is, at 3400, the power just went flat until around 4000 then back on the curve. Sound was just a bit off. Just like someone through an anchor out behind the car. it cruises just fine. Sounds great, but foot down at full throttle and as said at about 3400, bogs down. Fouled plugs? Valve float? Bad gas? Clutch going away?
it is a bone stock 3.2 with a g50, limited slip, PCNA clutch (which is chattering) in a 69 tub. Any thoughts are appreciated.
'86 944T black/red, chip, fuchs 8's and 9's- Sold
'97 Boxster silver/red, big mistake - Sold
'99 C2, silver/black, RoW M030 - sold
"69 912 white w/ '86 3.2L (like the pic, just not the pic)
Old 02-25-2017, 01:40 PM
Diss Member
Quicksilver's Avatar
You don't say what kind of induction you have. Is it Motronic or carbs?
(A plug problem should get worse at full throttle the higher you rev it.)
If it is Motronic I would wonder if you have a less then wonderful non stock chip or maybe the track in the barn door AFM needs to be re-arced.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-25-2017, 02:14 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1
'85 Carrera Targa
PCA/POC
Old 02-25-2017, 02:31 PM
There is a "dip" in that rpm area - but should not be as noticeable as you are indicating.
Sold: 1989 3.2 coupe, 112k miles
Old 02-25-2017, 02:47 PM
Rtrorkt's Avatar
bone stock fuel injection. Pretty sure the controller is as factory, but that could be an issue. Sound really changed briefly at the bog point. Once it got it's breath back it almost sounded like a turbo. Sort of high pitched air
Don't know. Will run it again tomorrow and see what happens. Scottsdale cops were all over north Scottsdale today
Old 02-25-2017, 03:10 PM
