Cooling fan belt adjustment
I can't determine if the nut holding the fan pulley in place is right hand or left hand thread.
The Bentley doesn't specify so I could assume it is a right hand thread but I don't want to force anything.
I'm sure many of you have done this so someone will straighten me out in short order.
Thank you
Old 02-27-2017, 04:48 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
It is right hand thread.
Old 02-27-2017, 04:59 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 ^^^
'85 Carrera Targa
PCA/POC
Old 02-27-2017, 07:22 PM
Thank you guys, better to be safe than sorry.......
Old 02-28-2017, 03:58 AM
To loosen anything that turns, the nut loosens in the direction it spins IE if it turns clockwise you loosen by turning clockwise . Loosen in the direction the fan blades spins or in the case of say a saw blade in the direction the teeth point
Old 02-28-2017, 05:28 AM
