Counterclockwise?
Power windows won't go down after a drive
Electrical gremlins drive me nuts.
After driving my 86 911 for an hour or so the windows won't go down.
They want to, but really struggle for the first couple of inches. If they go down a little you can get your fingers in and help them. Bottom 80% and up they are fine. In the garage they go up and down great all day long.
As well there are 2 other problems. Parasitic draw killing my battery and power windows work after you remove the key and open the door.
I took the door switch apart and cleaned it and it appears to have fixed the windows working after removing the key.
Was the switch also the culprit of the other 2 problems?
Driving me f###ing nuts and I can't drive the car because it's winter here.
Rod
1986 Carrera
2001 996TT
Old 02-25-2017, 01:31 PM
Alex599's Avatar
Have you tried degreasing, regreassing the regulators? They get seized up after 30 plus years!
1984 Carrera 3.2 Cabriolet
Old 02-25-2017, 01:48 PM
Counterclockwise?
I have the door cards off right now to check everything and they look great with lots of lube. Super fast with the car in the garage. Go up and down 20 times without hesitation. No glitches.
Rod
1986 Carrera
2001 996TT
Old 02-25-2017, 02:33 PM
Counterclockwise?
Could the sticky door switch create a load on the motor to make it sluggish?
Rod
1986 Carrera
2001 996TT
Old 02-26-2017, 09:12 AM
1979 911sc
Windsor4273's Avatar
My passenger door one did that for years. I figured it was just the regulator getting tired. Then the door switch on the driver's side went out that controls that window, and when I replaced it the window went up and down like it should.
1979 911sc
1969 Rover 2000 TC
2000 Ford Excursion
2015 Ford Transit 350
Old 02-27-2017, 06:47 AM
Counterclockwise?
Replaced all 3 switches and the relay.
Rod
1986 Carrera
2001 996TT
Old 02-27-2017, 09:35 AM
Counterclockwise?
Even though the window goes up and down fine in the garage, I took out the regulator to inspect.
Everything is perfect. I'll clean and re-grease, but it looks like I wasted my time.
Rod
1986 Carrera
2001 996TT
Old 03-01-2017, 07:18 AM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
The windows not working after driving thing happened to me and it turned out to be a vibration-driven intermittent at the fuse, probably exacerbated by some oxide on the fuse contacts.
Just an idea for one more thing to look at.
Old 03-01-2017, 11:52 AM
Eng-o-neer
Tremelune's Avatar
If it ain't the fuse, run a line directly from the battery to the switch(es). If they move with gusto when you touch the hot wire to them, it's the switch(es).
They are terrible switches, and tend to crack at the pivot point, which means you need to torque and wiggle them to get the contacts to touch well. If you lose the driver's side switch, sometimes the passenger side window is impacted as well, as the wiring goes through both. Ultimately a bad design that hasn't been corrected.
Old 03-01-2017, 03:11 PM
Counterclockwise?
Thanks for the help guys.
I understand what you are suggesting, but why does it go back to normal when the car sits?
Rod
1986 Carrera
2001 996TT
Old 03-02-2017, 08:13 AM
DanielDudley's Avatar
Check the fuse, clean the contacts and check the screws. Check the ground. If it is a common ground with other items, and it has a continuity issue, then it is taxed and getting hot, because it is being used by a different circuit.
It's most likely a continuity issue, so it is a bad connection, or a poor splice, poor power source, switch or ground. You start at the power source, and trace it to the end. And it's a bit like a legal document, the more you look at it, the more sense it makes. Getting a wiring diagram will help you.
Old 03-02-2017, 02:46 PM
Counterclockwise?
This would make sense as it is doing it after a long drive only. Thanks for the tip.
Rod
1986 Carrera
2001 996TT
Old 03-03-2017, 05:23 AM
