Brake MC Pressure switch replacement
If I replace the 2 pressure switches on the Brake MC, will it require bleeding the brakes after?
Old 03-01-2017, 12:42 PM
nop
Old 03-01-2017, 12:54 PM
wrxnofx's Avatar
negative.
The back one is kind of a pain to get off. Deep socket is too deep, shallow socket is too shallow. If memory serves, an offset box wrench is your friend here.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 03-01-2017, 01:22 PM
SCadaddle's Avatar
I had an assistant hold his foot lightly on the brake pedal when I removed each switch. Had a paper towel under the switch and only got a drop or two of fluid out of the master cylinder by the time I was able to thread the new one in. Didn't require bleeding the brakes in my instance, your experience may vary!
Old 03-01-2017, 07:58 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+3, no need but to be safe, press the brake 2" in, held by a 2x4 or a helper. get towels ready.
Brake a Leg
'85 Carrera Targa
PCA/POC
Old 03-01-2017, 08:30 PM
It is usually not necessary as mentioned in the posts above.
The actual removal and replacement is the tricky part. I presume you have read through the threads on doing the replacement. The offset box end wrench was the key to me getting it done.
Old 03-02-2017, 05:01 AM
This is a good opportunity to switch to a mechanical brake switch actuated off the brake lever.
Those pressure switches take more brake pedal pressure than I was comfortable with, as the brake lights often don't come on in stop and go traffic where you just barely touch the brake pedal.
HTH,
Chuck.H
'89 TurboLookTarga, 428k miles
Old 03-03-2017, 04:15 AM
Functionista
manbridge 74's Avatar
Tis more than likely your system could use a bleed. Do it.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-03-2017, 05:33 AM
+1 on Chuck H's comment.
1984 Carrera Targa
Old 03-03-2017, 06:43 AM
