Okay to have timing set to 10 degrees BDTC rather than 5?
Hello all,
while tuning up my 80SC I found that the car seems to run better set near 10 degrees BTDC, rather than 5 degrees. This is with the vaccum hose connected and the O2 sensor disconnected, 900 RPM's. I do not appear to get any detonation. I also to not seem to have a flat spot in lower RPMs any more. Can I keep it like this? Anything else I should adjust to compensate? I do not have a way to test the CO, but I did lean out the mixture until it began to run a bit rough, then richened it up until it ran well. Cross posted to Rennlist http://www.pelicanparts.com/ultimate/smile.gif cheers -Brad 80SC |
if it doesn't ping, run it. you should be able to go 35° total advance safely, with good gas. with that much total, you would probably end up with about 10° at idle.
| All times are GMT -8. The time now is 10:00 PM. |
