Wheel studs
Is it necessary to replace the wheel studs (with longer) when adding wheel spacers. I'm contemplating 20mm spacers on the rear axle. Thx
Old 03-09-2017, 03:09 AM
Cars and Cappuccino
tdw28210's Avatar
Hard to say for sure, but likely...see below
Minimum nut turns for safe use on Fuchs w/spacers?
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 03-09-2017, 05:45 AM
Topless crazy
seanratpel's Avatar
why spacers? Just add (whatever size) adapters. Adapter bolts to existing bolts, wheels bolt to adapter, very easy way less hassle.
Old 03-09-2017, 06:26 AM
wheel studs
I'm not familiar with adapters as I always thought spacers was what used to widen track, other than different wheels.
I'll have to search adapters and educate myself.
thx
Old 03-09-2017, 07:22 AM
Unless the spacer you are planning are relatively 'thin' I would suggest you use a Hubcentric design as it is much safer than a long stud.
Old 03-09-2017, 07:49 AM
Topless crazy
seanratpel's Avatar
Hugh: just go on Pel Parts catalog - you can look them & see what they look like. I've got, If I remember, 31 mm's on the back fit perfect, only took about 40 min's to put all 4 on!!!
Old 03-09-2017, 09:23 AM
Spacers can be thin as 3mm or as wide as are available in the marketplace. The determining factor is if the wheel studs engage the lug nuts adequately. If a simple spacer plate more than 3mm is installed between rotor and wheel, I suggest installing longer wheel studs.
Thicker spacers (~25mm or more) typically have their own stud arrangement that when installed, usually maintain an adequate amount of lug nut engagement.
Sherwood
Old 03-09-2017, 12:47 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Have you tried putting the ~20mm spacer on the rear yet? I think you'll find that when you place the wheel on the axle, you can't even get the lug nut to grab the threads
If your car is a typical "narrowbody" car, the original studs are 45mm long. So if you add 20mm of spacer, you need an additional 20mm of stud = 65mm. For comparison purpose, I bought H&R 14mm spacers and with them they provided 66mm studs.
I've also installed 28mm 930 spacers on the rear of Carreras and used 930 rear studs that are 72mm long. 45 + 28 = 73 = close enough since that's what Porsche provided for the 930.
I recall this thread provided a nice photo tutorial and as luck would have it RoyB's link still works.
Wheel Stud replacement...A pictoral..
Kevin L
'86 Carrera "Larry"
Old 03-09-2017, 01:10 PM
Thanks guys. I haven't purchased spacers so I was just gathering information in the event I want to go in that direction. You've all been very helpful.
Old 03-09-2017, 02:48 PM
I think you need 7-8 full turns of the lug nut for positive engagement
Old 03-09-2017, 05:45 PM
Bill Douglas's Avatar
An interesting thread - thanks guys. It's one of those projects I keep thinking (procrastinating ) about.
Old 03-09-2017, 07:27 PM
The factory used 21mm spacers on several cars and coupled them with 66mm long studs.
Old 03-10-2017, 08:32 AM
