89 964 C4 Engine Removal
Do I have to bleed the hydraulic ABS system to remove the engine?
Not to remove it but you will after reinstalling it.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
Don't open any hydraulic lines. Just remove the servos from the trans and tie them aside. The one on the trans nose cone can be difficult to get loose, but be patient.
Thanks so much all. As far as where the trans shaft meets the torque tube. Is it difficult to disconnect in order to drop the motor?
