Warning about dash LED bulbs
I searched on this topic and couldn't find anything, so apologize if already covered.
I recently replaced my dash bulb lights with Superbright LED's. Took it out for a drive and noticed no charging was happening - the red alternator light wasn't going out and my volt gage was only showing 12V, not the standard 13.5. Killed my battery. Long story short, I replaced the alternator bulb back to standard and all good now. Guess because current from the blue wire from the alternator passes through the bulb, it's not happy with the LED. Anyway, just an FYI.
'72 911T '73 MGB (sold) '71 Alfa GTV (sold) |
Yes, the alternator needs the resistance from your dash light bulb to activate your charging circuit. That's one bulb that I didn't change to LED. You could add a resistor to the circuit though and make it work. That was too much work for me. Haha.
Craig '69 911T |
I put the LED bulbs in my dash quite some time ago. 1974 model. No problems.
2013 Speed Yellow 991 Cab 1974 Silver 911S Targa 3.2 1997 993 Cabriolet 1958 356A Sunroof Coupe 2002 Rover P38 Borrego |
Driver, not Mechanic
I got LEDs from another Pelican. No issues since 2013.
Only a few months but my 89 is a daily driver and no issues here.
James 1989 Slate Grey 930...sold ![]() Looking for the next one! |
"No issues" is not the point of this thread. Are you saying your alternator light works? You tested it?
OP is saying you will not know your alternator light isn't working until you're on the phone with AAA.
1986 Bosch Icon Wipers coupe. |
He said red alt light wasn't going out which I took to mean it was on, and battery was in use. No?
