Lost in parking light/turn signal wiring, help!
Howdy Pelicans,
Firstly, let me start by saying that I'm an electrical dullard. I can do a lot of things but electrical is just not one of them. What can I say, I just have a hard time wrapping my head around the basics. Anyhow, in the process of disassembling the bumper and all associated guts, I decided to detail all the components and possibly find out why my # 9 fuse kept on blowing and why the front driver's side signal flashed dimly. Here's what I found. Someone has been busy in there fixing things. Where does this plug go? I can't find a male end? Now this is the real ***** show. One of the lens screw was loose and water came in and ravaged this homemade repair job. Also, you'll notice that one of the plugs was broken off at the housing. After looking, it looks like it leads to nowhere... what are my options here? Buy a full assy? Thanks all!
1984 Carrera 3.2 Cabriolet Last edited by Alex599; 03-16-2017 at 04:04 PM.. |
ROW '78 911 Targa
Brown is ground in first photo.
Judging by condition of second photo I would suspect the ground tab was broken off by a PO. Find a good used set or go all new.
I am surprised the photo is not blurry.
you have a white wire blending in with the brown all hidden by the connector in the foreground. the connector on the white wore or the brown wire how about a better pic
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Yes, brown is ground wire. It wants to connect to the bulb housing. Probably the tab is broken off. But this is why dim light and blown fuse.
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
RETIRED
Get a volt meter or test light. Check to see if the power lead is getting power after replacing the fuse.
If you find that the power wire has 12v when connecting the alligator clip to the power lead and grounding the tester. Check if the bulb is good. Renew the ground wire find a good source of ground and use an eyelet and self tapping screw. You should be good to go. You just passed electrical 101.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thanks guys!
I'll confirm that once everything's back in place and working, thanks Joe Bob!
1984 Carrera 3.2 Cabriolet |
The ground location is on the pot metal piece. If memory serves, this is it:
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
RETIRED
His pic doesn't show that side where the male connection for ground is but one could assume it is missing or broken off. Hence my suggestion for an eyelet and a self tapping screw.
