Dumont's Avatar
Power antenna wire routing
I have my new antenna in hand and am wondering if someone could chime in or shoot a photo of the wire routing. Mine goes from the antenna, 3 wires, two power and one antenna, through the firewall, but it looks very "unfactory" like someone at some point jammed them through a hole and then doped it all up with electrical conduit seal/putty.
I guess that will work and I'm fine with it if that's what's done but I can't find any reference or photos to confirm.
79' 911sc
Old 03-16-2017, 05:44 AM
Dumont's Avatar
Anybody? Bueller?
79' 911sc
Old 03-16-2017, 11:42 AM
Banned but not out, yet..
RSBob's Avatar
Bueller here. You may want to toddle down to your hardware store and buy a rubber grommet which will fit said hole. Punch a hole through the grommet and feed through the wires.
I have a power antenna and used an exiting grommet through the firewall on the passenger side under dash.
Old 03-16-2017, 07:53 PM
What year? This is the routing for my 79. Antenna above and three wires in a black conduit below. Brown to the common ground above the heater control, white to the radio and red to an inline fuse that connects near the ignition switch.
Derrick
Old 03-16-2017, 09:22 PM
Dumont's Avatar
79
Thanks much to both of you. Just what I needed.
79' 911sc
Old 03-17-2017, 04:58 AM
