3.0 to 3.5 Litre Rebuild with ITBs, Motec, EFI
pls delete this thread..
Last edited by mikedsilva; 12-18-2020 at 04:00 AM.. Reason: Want to change title!! |
TOO Much time on my hand's comes to mind.
beautiful job..but...looking at your clutch arm ..it does not seams it is fully pulled back for correct adjustment
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Anyone know how to change the title??
Hi Mike somehow i do not think so, the clutch arm seems way towards the front of the car ...it should be strait not in an angle look here..
915 clutch arm & spring arm assembly install Did you when you install and hooked the cable pull back with a screwdriver on the arm to load the Omega spring?? like this?? https://www.youtube.com/watch?v=vNdMp_W-cmY
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 12-18-2020 at 01:14 AM.. |
Sorry, I deleted this to start a new thread.. for some reason, I wasnt able to change the title of this thread from "Delete"..
Sorry about that. |
I think the only thing you can do is email one of the moderators or possibly Dimitry.
Walt 82SC 3.0 81SC 3.6 |
Mike, do not worry to much at least it stands out;-)
ivan
Mike did you delete those pictures??it was all looking very nice,why?
Ivan
