Tie rod end removal questions
Hi Pelicans:
I'm continuing the refresh of the suspension on my '83SC. Two questions for the evening.
The turbo tie rod ends are giving me trouble. The steering rack is on the car. I see the "flats" of both the ball joint assembly and the tie rod shaft, and tried using proper size wrenches on them, but they are not budging. Any tips for removal? I've got Kroil on the exposed threads right now.
Second, I've measured from the end of the tie rod boot to the center point of the ball joint shaft (9 1/4" in my case). Will this measurement be adequate to rough in the new assembly?
Thanks!
Old 03-23-2017, 07:29 PM
Dial 911
A horse with no name's Avatar
Originally Posted by garment View Post
Hi Pelicans:
Thanks!
Are you just trying to replace the tie rod ends?
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 03-23-2017, 07:58 PM
You know, a picture says a thousand words...
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-23-2017, 08:35 PM
Can do!
Old 03-24-2017, 06:00 AM
Spiderman
Jesse16's Avatar
To your first question, you should just have to hold on the flats on the the ball joint casting side (where your 7.5" dimension is) and break the lock nut free. Mine have never been that tight and you should not reef them really tight when going back. Kroil or other can't hurt. Maybe some heat on the nut as long as you keep it away from the seal if you're not replacing. Yours look pretty good. No idea on the dimension, just leave it loose till you assemble.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 03-24-2017, 06:27 AM
Just had an Ah-ha moment - wasn't aware that there is a lock but threre, seems like time and dirt has obscured the point at which the ball joint casting and lock nut meet. At least I know wat to go for now! Thanks!
Old 03-24-2017, 07:12 AM
LIke I said, a picture says a thousand words. Lock nut.
Old 03-24-2017, 07:23 AM
