Can anyone ID this missing under dash wiring terminal plug
I am cleaning out some old wiring from under the dash to my Rat Rod, and wanting to get the hazard switch hooked up. The factory harness has not been missing any wires to date, but I cannot find a lot of wires that should go to the hazard switch. While under the dash I notice this plug missing. Hmmmm...
For perspective that empty plug is the the left and above the main row of plugs, and the smaller HVAC hose you see feeds the dash vent on the drivers side, while the larger HVAC hose on the far right of the pic runs from the dash down and into the drivers side door sill (its heat obviously). Any clue what that plug feeds? http://www.pbase.com/image/165148267.jpg |
I'm guessing you're missing thharness between the hazard switch and body
part # 911.612.014.30 |
Anyone else have a guess or are we SURE its that plug? That part is NLA...hmm
Are all your switches present and have wires coming out of them going to their respective plugs? IIRC, those two plugs are for the headlight and flasher switches.
Did not doubt jrbennett......just looking for a larger sample than 1. Thanks cnielsen...now I need to find one, since its NLA. Kroon maybe. hmm...
I could cast/build you a new one, what year do you need?
(If you are sure that is what is missing) Or just post a WTB in the classifieds. |
We can deliver all years directly from stock. Depending on the year of your car the harness might also need a resistor. Have a look at our website www.kroonwireharnesses.com or just contact us by email at info@kroonwireharnesses.com
one of those plugs feeds the turn signals/lights and the other one feeds the wipers. They both come directly from the switches on the steering column so one of those two is missing.
Thank you EVERYONE! I scavenged the harness from a 1986 Targa near my house. :) I plugged it in and replaced the flasher relay but no joy. I have not had a chance yet to R&R the issues (check the relationship, etc. I do know the '86 harness has a resistor in it. The switch is new, so that and the relay are not the issue. I will report back.
Any clue if a 75 needs the resistor found in the 86? |
Link to '75 schematics
https://www.dropbox.com/sh/oswepkzym8agnt6/AAAR8QHZ8BO3BbkSNqVwvL2Ma?dl=0 |
| All times are GMT -8. The time now is 06:36 PM. |
