nippy's Avatar
RS DOOR PANEL LOCK DIAL PROBLEMS (sticks out to far)
Anybody run into this? Car is 82sc ROW. The dials don't go down flush.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold)
Old 03-18-2017, 10:16 AM
What you need to do is glue some closed cel foam on the back side of the door panel around the opening. Maybe some thats 1/4 or half inch inch thick to tighten it up.
1982 911 Targa, 3.0L ROW with Webers
Old 03-18-2017, 10:56 AM
I have some left over, where are you located?
Old 03-18-2017, 11:02 AM
Retired Member
Brian 162's Avatar
I had the same problem. I put foam pipe insulation behind the panel. It was maybe 1/2 of an inch thick. It worked.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 03-19-2017, 10:49 AM
Contact rennline. If that is their kit your missing some plastic spacers they now supply to push the trim ring back
Old 03-19-2017, 01:31 PM
83 911 Production Cab #10
JJ 911SC's Avatar
I fix that problem by going with out it.
Who Will Live... Will See
Old 03-19-2017, 01:46 PM
Diss Member
Quicksilver's Avatar
I can't see making the car openable with a simple coat hanger.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-19-2017, 07:42 PM
Formerly known as Syzygy
Canada Kev's Avatar
The opening strap has nothing to do with the locking dial. He was just showing his door panel with the dial deleted.
EDIT: Ok, never mind. I suppose the locking plunger by the vent window in his example could be opened with a hanger. Using a different style plunger that wouldn't be susceptible to that would be prudent.
Kevin
Old 03-19-2017, 08:17 PM
JJ 911SC's Avatar
In the last 7 years the roof has been up 5 times... But its a consideration.
Old 03-20-2017, 01:59 AM
I will definitely delete mine next time I reskin my RS panels - in 25 years I have NEVER touched those dials! I already deleted the central locking button when I removed my center console...
Chuck.H
'89 TurboLookTarga, 429k miles
Old 03-20-2017, 04:50 AM
