GPS Speedometer Sensor Install
Gps speedometer conversation
I was looking into a GPS sensor for my Rat Rod. There was another thread discussing them , but I thought it was best to post this here, on it’s own. There are several GPS Speedo Sensors on the market like the Intellitronix. None of them work for us as it they are not adjustable to mimic the 6,400 Pulse Per Mile (PPM) our Porsche speedometers need. So I kept searching and a unit from Autometer. It appeared to be infinitely adjustable. I read the instructions on line and thought it was worth a try. You use an adjustments button to adjust it to read dead on 80mph (while in your driveway of course, through a setting mode). It then memorizes the setting for that and you are all set.
Autometer GPS Speedo Sensor
So I ordered it and installed it……but my speedo was dead, but thanks to a friend (who had 4 sitting around) I found 1 that works. Calibrating this thing was EASY.
To install I just hooked up the power and ground the Autometer unit needs to the power and ground that plugs onto the back of the gauge. The signal wire for from the Autometer “brain” REPLACES the signal from the tranny sensor. I stuck the antenna under the dash pad. It is magnetic, so I just stuck it to the dash board metal in where the speaker would go (1975 with center dash speaker). It needs to have a clear view of the sky (meaning no metal on top of it) and it can shoot through plastic/fiberglass/etc. Once hooked up you press and hold the calibration button until the needle rises close to (but below) 80mph. At this point you press the button to make the needle rise a little until it is dead on 80 mph. Once there wait 5 seconds, the needle will drop to zero and you are calibrated. I had to do it twice, the first time I had the speedo in my hand. Once in the dash I realized the angle to my eyes as I drive was different. So I recalibrated it while it was in the dash and I was in my driving position and it is now dead on.
The one catch is with key-on power the speedo doesn't read until the unit gets a GPS fix, which takes a few minutes if the car was off over night. You can hook its power to the battery for a faster fix (obviously this causes some drain, but it is minimal).
Obviously in a long tunnel or parking garage it will lose its signal. The longer I have had to wait though is about 2 in. No big deal. I am VERY happy with this though. I put a new sensor on my tranny and ran new wires, but that did not work. Now that I have realized my speedo was dead, maybe the sensor did work, maybe not. Regardless, now I have a GPS system that can be adjusted for any tire size changes. The install was literally 30 minutes, and the calibration took 2 minutes.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-22-2017, 06:53 AM
Registered Minimalist
75 911s's Avatar
Good info Chris. Been using my traffic app as a back up GPS speedo, but this is a nice permanent setup. Looked around a bit, but didn't see any pics of your 75 hotrod - can you point me to a thread?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 03-22-2017, 08:14 AM
Here she is at Works Amelia 2017.
I thought I had started a thread on her......looks like I have not! Shame on me. Maybe a intro thread is needed. Hmm..
Old 03-22-2017, 11:40 AM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
Love this, any more updates from anyone on GPS speedos
Old 04-26-2020, 06:48 AM
Cairo94507's Avatar
Hi Guys,
I have a later model Carrera speedo in my '71 914-6 because my car was at 86,xxx miles when we disassembled it for a full restoration and some minor mods. I did not want to lose the original miles, my speedo/odometer worked when we parked the car and I have paperwork supporting the mileage, so I decided to go with a newer speedo to add the extra digit. Great idea that has turned into a slight problem. I have now bought 3 speedo GPS units and we are still trying to sort this out. The current one, I am not sure of the manufacturer as the shop doing the work purchased and installed it, is working mostly but reading low. They are trying to calibrate it to be accurate and thus far have not got it dialed in. Anyway, I forwarded this thread to them to see if the OP's post might be of some assistance. Thanks and cheers, Michael
'71 914-6 #0372
'17 Macan GTS
Old 04-26-2020, 07:10 AM
