911 electical?
Hi All, I have a 78 911sc with a 1980 3.0. My problem is starting cold. It takes a few minutes of turning over before it finally starts. Once its warmed up it starts with just a bump of the starter. Any ideas ?
Thanks Blair |
Administrator
Hi Blair - check out the link below to one of our DIYs, hopefully it'll help you troubleshoot the starting issue you're having. If you have anymore questions, feel free to post a Comment just below the article and we'll do our best to give you details.
Porsche 911 Starter System Troubleshooting | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article -Dmitry |
Thanks, will try the book.
Blair |
ROW '78 911 Targa
Search the forum for CIS for Dummies thread. Likely a fuel system problem VS electrical.
If the starter is cranking, it isn't an electrical problem.
that does not apply.
you want to look at: cold start valve (CSV) and circuit cold control pressures air leaks (making it lean for cold start)
Check your vacuum lines
Check these suggestions.......
You need a pressure gauge to troubleshoot your problem. If you don't use a pressure gauge, you will be doing a lot of guess-work and would rely heavily on luck. Tony |
Slow starting.......
The fuel pump has a valve on it that is supposed to hold fuel pressure. If the valve goes bad, the pressure leaks down quickly and then it takes a bit of cranking to build up enough pressure to make the fuel injectors squirt. Put a fuel pressure gauge on the engine and see how fast the pressure leaks down. Good luck!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
