franklinstower's Avatar
Bilstein Strut insert Q's
I have one strut that appears to be leaking on my '78sc.
I have a pair of used replacement struts - however, there are no markings on the struts or part numbers, so I was wondering if any could help identify these.
and secondly, they compress to different lengths? one compresses down to about 1.5" of the shaft remaining exposed, the other leaves about 4" exposed?
They both seem to have about the same pressure. Any reason not to use these?
Thanks,
Paul
'78sc coupe / 89 Westy - EJ25 frankenmotor
Old 03-23-2017, 11:30 AM
I'll play devils advocate and say that for your time and effort and the relatively low cost of new inserts, I'd question the wisdom of using used parts here.
Especially now that you have an issue with one of them though I am no expert. Just been doing a lot of research on this job and parts lately as I want to get it done myself.
I see that you are local too! Let me know how you rate the difficulty of putting them in.
1982 911 Targa, 3.0L ROW with Webers
Old 03-23-2017, 12:27 PM
Rescuer of old cars
Arne2's Avatar
In my experience, a Bilstein insert that won't compress all the way is low on oil, and the floating piston that separates the gas and oil has moved and is interfering with the travel. If so, it needs to be replaced or rebuilt.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 03-23-2017, 01:39 PM
Ok, thanks for the info Arne2.
Shouldn't all bilsteins have a part number stamped? I'm still curious about the lack of any identifying marks.
Old 03-24-2017, 07:15 AM
