Anyone use a diffrent design Window switch?
I have OEM. To me it seems the design is not robust. By that I mean the toggle switch itself, the movement that is there other than up and down. I noticed that 924/44/68 cars use a simple rocker switch. Seems to me that would not have the same issues as our 911 switch. Has anyone replaced the 911 switch with a different unit completely?
I know I started an earlier thread but I could not work out how to change the name to better describe the information I was really looking for. |
The 924 et. al. use VW/Audi switches... they are Audis.
See your other post on the same exact topic. |
there were some old threads about 80's BMW switches, nice design, push-button for up/down, used similar spade connectors, and almost the same size, slightly larger, so some minor modification to the door panels required.
Check out your other thread, we posted some suggestions there.
-Dmitry |
The switches from the revised interior are also used in the 928, 964 and 993. (However the window switches are not shared - with the exception of one rare 993/996 model). As for if the window switches are better or stronger, I can't say. However they are not plug and play. Most modern window switches seem to be fairly robust, however are usually meant for mounting on a horizontal plane (armrest) and would be awkward on a vertical panel. |
| All times are GMT -8. The time now is 08:19 PM. |
