rdane's Avatar
Big Bore throtte bodies on a SC?
What can you tell me about this mod? Is it worth the $600 or so it will cost with parts (300) and labor in peformance improvement?
Old 01-19-2003, 07:01 PM
Chuck Moreland's Avatar
If your SC is otherwise stock, save your money. That engine is limited by the exhaust. Your money would be better spent on a set of SSI or early heat exchangers.
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-19-2003, 07:07 PM
rdane's Avatar
I have SSIs and a stainless sport exhaust. Now what
Since I have your attention Chuck I am thinking the Elephant Racing, Finned Oil Lines instead of adding a front oil cooler beyound my basic trombone system for the moment. Going to change bumpers later on and am thinking the lines will lower the track temps a little and would be a good intermediate step before the major rebuild an bumpers.
Good idea or not? Will it bring the oil temps down enough to do it now or should I wait on the cooler?
Old 01-19-2003, 07:11 PM
$600??. Try $200 and very little labor. Is it worth it? As a stand alone modification, no. If included with high flow intakes (MAF) then yes.
Old 01-19-2003, 07:27 PM
You will see an immediate reduction in track temps with that approach, likely 20 degrees or more. If you do the bumpers/valence cooler later you'll continue to use the finned lines and your investment is still good.
Old 01-19-2003, 08:08 PM
jluetjen's Avatar
If you have a '79 (with the larger intake ports) with SSI's or early style exhaust, I'd suggest the thing that is limiting your HP at that point are the cams. Go for some 964 cams. A larger throttle body may help at that point, but I'm not conviced. I suspect the next step after replacing the cams is to pitch the CIS (and associated pistons) and go for carbs.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-20-2003, 05:16 AM
Metal Guru
911nut's Avatar
I talked to Performance Products about this mod and they claim improved throttle response.
Someone with a flow bench needs to measure flow through the sensor body and then the stock throttle body to find out if increasing throttle body diameter would be worthwhile. If the throttle body flows less than the sensor body it might be worth doing. The danger is, however, that the fuel distributor calibration could get messed up.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 01-21-2003, 05:32 AM
Irrationally exuberant
ChrisBennet's Avatar
They also sell Splitfire spark plugs as well. 'nuff said.
-Chris
Old 01-21-2003, 05:36 AM
rick conrath's Avatar
Cool
Go straight to the source for your throttle body enlargement, as opposed to the middleman. I have spoken with the gentleman who does the work for many of these performance shops and lists his service in Panorama. It is much cheaper to send out your throttle body for the mod's, than to buy a new one. No data to support it as a useful upgrade that I am aware of. If it makes you feel faster go for it, otherwise I would save my money for the proven performance goodies.
Old 01-21-2003, 01:39 PM
