-   -   Front strut rebuild questions (http://forums.pelicanparts.com/porsche-911-technical-forum/950934-front-strut-rebuild-questions.html)
brasch 03-26-2017 01:55 PM
I am rebuilding my front suspension, the part numbers on the struts are hard to read somimm it sure what to buy for inserts? I have 19mm front torsion bars and a 22mm sway bar, anyone have recos? I have koni classics in the rear, not sure if I should keep Konis up front too?
http://forums.pelicanparts.com/uploa...1490561649.JPG
brasch 03-26-2017 02:09 PM
Better pictures of the struts
http://forums.pelicanparts.com/uploa...1490562495.JPG
Trackrash 03-26-2017 02:49 PM
Look like Boges. What year car?
What brakes? 3 inch bolt spacing?
If you pull out the inserts you have it will be more obvious.
Now that they are cleaned up, you should be able to see a stamp somewhere.
You should be able to get Koni classics that will fit.
brasch 03-26-2017 03:12 PM
3" spacing M calipers now, I'm looking for 2" Alfa brembos
