Alex599's Avatar
Help needed removing shift rod bushing
Howdy Pelicans,
I'm a bit stuck. I replaced my shifter bushing and the two coupler bushings but this one has me stumped. I can seem to get the shift rod bushing passed this "bulge" (end of screwdriver). I tried tapping the end of the rod with a hammer (coupler is still out) and pulling from the transaxle end without success.
Is there a trick to it? Any help would be appreciated.
Thanks,
Alex
1984 Carrera 3.2 Cabriolet
Old 03-27-2017, 02:20 PM
Alex599's Avatar
Anyone?
Old 03-27-2017, 04:56 PM
Normally not a bulge there. Probably a plug weld repair that needs to be ground down.
206 637 4071
Old 03-27-2017, 05:03 PM
Alex599's Avatar
Alright, that's what I thought. Here's a better picture.
So my next question is, how do I check if the rod bushing needs replacing? It was a "while I'm in there project" but now I don't want to tackle it if I don't need to. I'll keep it for next winter's project if it can wait.
Thanks,
Alex
Old 03-27-2017, 05:10 PM
clarkd's Avatar
I replaced mine because it was brittle and crumbling apart. Most likely due to age.
Old 03-27-2017, 06:01 PM
Do it now, or do it later, but it's got to be done at some point. It's really not that big a job, however grinding down that weld might be a PITA.
Its hard to tell from the pic but your current bushing doesn't look too bad. I've seen some real gnarled ones before.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 03-27-2017, 06:11 PM
Alex599's Avatar
I'll wait till my next (first to me) engine out service to replace the rod and bushing.
Thanks all!
Old 03-27-2017, 08:27 PM
Brew Master
cabmandone's Avatar
Thanks all!
If you need a shift rod let me know. I have one that I have been saving but I'm not sure exactly why I'm saving it. I'd just grind the welds on the one you have down and move on.
Old 03-28-2017, 04:01 AM
tobluforu's Avatar
Do you have a dremmel, man do i love mine, it has saved me many a time.
Old 03-28-2017, 07:16 AM
Alex599's Avatar
Thanks, I may take you up on it.
I do and I've thought about it. I'm just terrified that I'll screw up the weld and have to drop my motor to change the rod.
Old 03-28-2017, 09:28 AM
