-   -   Can the window channel be replaced without taking the door panel off? (http://forums.pelicanparts.com/porsche-911-technical-forum/951169-can-window-channel-replaced-without-taking-door-panel-off.html)
Joe V. (guest) 03-28-2017 11:13 AM
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Casey at Pelican Parts 03-28-2017 11:13 AM
I don't think so...
- Casey
gptom 03-28-2017 11:26 AM
I just did this & there are bolts behind the panel
john walker's workshop 03-28-2017 12:07 PM
If it isn't glued in, yes. Basically, you pull the old one out, spray silicone down the channels and on the last 12 or so inches of the new rubber and start to feed it in with a flat screwdriver blade. when it doesn't want to go anymore, raise the glass 2" and hold the screwdriver on an angle against the felt, and resting on the edge of the glass and keeping downward pressure on the felt. Lower the glass and follow it with the screwdriver. Repeat as needed. Don't silicone the upper part of the felt channel that goes into the visible frame.
jmdrvincent 03-28-2017 08:52 PM
John, thanks for that suggestion. I will try it this weekend. I am assuming that no adhesive is needed, that the channel is a pressure fit?
Dmitry at Pelican Parts 05-01-2017 02:32 PM
Correct, no adhesive needed.
