Joe V. (guest)
Guest
Posts: n/a
Can the window channel be replaced without taking the door panel off?
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 03-28-2017, 11:13 AM
I don't think so...
- Casey
gptom's Avatar
I just did this & there are bolts behind the panel
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 03-28-2017, 11:26 AM
If it isn't glued in, yes. Basically, you pull the old one out, spray silicone down the channels and on the last 12 or so inches of the new rubber and start to feed it in with a flat screwdriver blade. when it doesn't want to go anymore, raise the glass 2" and hold the screwdriver on an angle against the felt, and resting on the edge of the glass and keeping downward pressure on the felt. Lower the glass and follow it with the screwdriver. Repeat as needed. Don't silicone the upper part of the felt channel that goes into the visible frame.
206 637 4071
Old 03-28-2017, 12:07 PM
joebob
John, thanks for that suggestion. I will try it this weekend. I am assuming that no adhesive is needed, that the channel is a pressure fit?
Old 03-28-2017, 08:52 PM
Administrator
Dmitry at Pelican Parts's Avatar
Correct, no adhesive needed.
Old 05-01-2017, 02:32 PM
