I'm probably the 3rd or 4th owner of my '87 911 Coupe and it has a limited slip differential, but I have no idea what brand it is. Here's a picture of it when we rebuilt the gearbox a while back.
Any guesses?
I did some google image searching and found another thread and it looks like this is a stock Porsche LSD...? From what I've read, Porsche did not offer LSD in 1987, so I'm guessing a previous owner put this in at some point...?
RETIRED
My 83 has an oem LSD. What is the trans' part number on the spine on the bottom?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Joe Bob, I'm not sure as this sucker is back in my gearbox already and I didn't take any other photos
![]() However, this is for a g50 box, so probably not the same as the one you have for your 915... i would assume. |
RETIRED
Well, the number will tell if stock, but the previous owner coulda added it.
Pelican user Matt Monson could probably tell from your picture.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
gearhead
Very simple... A factory ZF G50 LSD will have a part number starting with 406 stamped in the side. If it was original to the car, the gearbox will have a 2 stamped between the G50/00 type number and the start of the serial number. If it has a 1 instead it was an open diff.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks, Matt! I'm changing my gear oil this weekend, so I may peek in there and see if I can locate a part number without tearing too much apart. I'll check the gearbox S/N, too. That's super helpful in figuring out this little mystery. I really appreciate everyone's help here.
If the trans has a 2 stamped between the G50/00 type number and the start of the serial number, please try and get a photo of it; it makes great documentation.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
