The Final Solution... Maybe
So I am in the final stages of setting up my 914-6 conversion project with a 1982 SC 3.0 with a grind from Webcam (20/21) set at 1.9-2.2mm with .1mm lash / lobe center on intake is 1143 degrees and 112 on exhaust /
I hae a nice set of 914-6 Weber 40's very clean with new rebuild kits installed. My question is this: What is the best combo of jets, venturi's, and other internals for initial warm up and run-in? Now is the time for me to start on the right foot / I can re-tune later but initially, I would like the best chance of a running engine to break in and check all oil cooler lines etc. Any thoughts for experience would be greatly appreciated. Cheershttp://forums.pelicanparts.com/uploa...1491096776.JPG http://forums.pelicanparts.com/uploa...1491096776.JPG http://forums.pelicanparts.com/uploa...1491096776.JPG |
Uh...perhaps a poor choice of a title for this thread?
Not a good choice of words
A bit like referring to the SCCA finals as the master race.
I can't help with the jetting though. |
Not an expert by any means but you could start with either 36 or 38 venturies, 160 mains, 185 air, F16 e tubes for starters. Maybe keep 150 mains on hand along with F11 e tubes as well.
https://en.m.wikipedia.org/wiki/Final_Solution Sent from my iPhone using Tapatalk |
thanx tito i did not want to be so strait ..so i took off my comment..
ivan |
| All times are GMT -8. The time now is 03:41 AM. |
