-   -   83 SC: Sunroof stuck at guide rails on passenger side (http://forums.pelicanparts.com/porsche-911-technical-forum/951856-83-sc-sunroof-stuck-guide-rails-passenger-side.html)
83_Silberpfeil 04-02-2017 02:15 PM
My 83 SC sunroof is stuck. Need to access the guide rails, but the roof will not open even manually, and I am unable to remove the roof panel.
I cannot see what it is, but seems to be something clogging the guide rails on the passenger side.
As, I attempt to open --- both via motor/switch), and also manually vial the special tool/crank --- the roof opens may be 1/4 inch, then you can see that:
- the passenger side of roof stops moving
- driver side keeps moving for another 1/8 inch
- the roof panel becomes misaligned
- the driver side begins to lower, as it should into the roof
- the passenger side remains stuck
So, then I try up front to remove the liner attached to the sunroof piece, but unable to grab/hold the front edge because roof is closed. I've disengaged the motor/clutch from the cables and tried to push the roof back, but it does not move
How to proceed?
Thanks!
proporsche 04-02-2017 02:22 PM
Hi if you have the headliner off ..now you have to remove the gears so the sunroof is no longer attached to them..front is 8mm socket on the rails and the rear is 7mm socket.Then gently remove the sunroof from the car.Just be gentle so you do not scratch the roof...
Ivan
http://img.pccreation.net/photos/201704022322009431.JPG
83_Silberpfeil 04-02-2017 03:01 PM
Thanks!!! Esp the 7 & 8 mm sockets.
I followed this thread and was able to remove the roof. http://forums.pelicanparts.com/porsche-911-technical-forum/376404-sunroof-cable-repair-new-seals-87-911-a.html
Ivan
83_Silberpfeil 04-02-2017 03:08 PM
Now I have the roof panel completely removed/off.
Here's what I see:
Passenger side, the cable is slotted/fit into the "outside" of the guide rail.
Driver's side, the cable is slotted/fit into the "inside" of the guide rail channel.
Does this seem correct?
I am able to see that that on the Passenger side, the cable is no longer attached to the "cable holder". Kind of like the first pic of post #2 on this thread...
What should next step be?
proporsche 04-02-2017 03:11 PM
Hi..most likely next step is to remove the cables..probably broken...and inspect..picture would help
Ivan
83_Silberpfeil 04-02-2017 03:35 PM
Thanks again for continued interest/support.
I took the cable holder out of the guide rails. See how the cable rides on the "outside edge, on the passenger side? And on the driver's side, cable rides on the inside edge? Is this how it is supposed to be?
How do I remove the cable? use pliers and just pull it out?
Ivan
83_Silberpfeil 04-02-2017 03:40 PM
Here are some pix...
http://forums.pelicanparts.com/uploa...1491172796.JPG
proporsche 04-02-2017 04:18 PM
Hi ,this is the solution to your riddle..
You have to remove the sunroof rails piece by piece..the rest of the cable will come with the rail.
There is plenty of help on this forum as you just looked at the another one.
It is not really hard to do .The only thing is be careful once you get the new cables in and start to insert the sunroof it self , you do not scratch it..
good luck
Ivan
83_Silberpfeil 04-02-2017 04:19 PM
More pics here...
You can see that the cable attaches on the 'outside' of the cable holder. Cable rides on the 'outside edge' of guard rail...
Ivan
http://forums.pelicanparts.com/uploa...1491175103.jpg
proporsche 04-02-2017 04:28 PM
This is something..it was actually working?Are you really saying the cable was ridding on the top of the rails?
The cable must be inside the rails in order to properly work...
83_Silberpfeil 04-02-2017 06:30 PM
Of course the cable was inside the rail 'track'.
Because cable broke from cahle holder, I had to use plier to pull cable out separately from guide rail.
proporsche 04-02-2017 11:50 PM
ok misunderstood...in this case it is no brainer. Get yourself new cables and reinstall..
If i remember correctly you have to modify the sliding ends to fit your rail.Maybe they do the cables different now i do not know ...but that was the case last time i did the cables in LA.
Ivan
83_Silberpfeil 04-03-2017 01:47 PM
thanks! will do!
Ivan
83_Silberpfeil 04-04-2017 08:48 PM
Going to go on the cheap and try to salvage and refurb/reuse the existing cable and slider. Followed jhubs' ide here on his post #2 below. Used some Goof Off to clean the cable tip and the slider. Then applied a bit of JB Weld Steel Stik to the tip of the cable. Surprised to learn it was like 'putty'. Tried my best and inserted cable into the slider crimp tube.
See my fotos below. The 'crud' on the cable at the slider is the JB Weld putty.
http://forums.pelicanparts.com/uploa...1491364067.JPG
Hendog 04-04-2017 08:52 PM
Yep, I did this same repair last year. I cleaned up the cable end and inserted it with JB Weld and also "crimped" it (applied squeeze pressure with some device). Then I filed it with a hand file to make it smooth so it wouldn't bind/catch anywhere. It's been good since.
83_Silberpfeil 04-04-2017 09:05 PM
Thanks Hendog. Good tip --- I will crimp and file.
83_Silberpfeil 04-08-2017 04:38 PM
@Hendog --- crimping seems to work well, giving it an extra hold. Thanks for the tip.
Made some progress today. Let me share what I did, and what I learned.
Worked on cable tracks further today under daylight. Was able to see that there was much more gunk (grease, dirt, foliage, etc) inside the tracks. Used Goof Off to further clean the tracks. Turned out that the gunk stopped the passenger side cable holder from traveling back (to open) along the track).
I would be inclined to believe that the cable/track system should run w/o grease, as lots of dirt can gum up the operation.
Since I was at it, I also removed the driver's side cable/track --- gave it a good cleaning w Goof Off. Just as dirty as the passenger side --- but did not have issues riding up/down the track.
So, for anyone w a sunroof coupe, where the sunroof is not operating a smoothly (based on visual and audio cues) I highly recommend removing and giving it a good cleaning.
83_Silberpfeil 04-08-2017 04:52 PM
The parts arrived from our Host. Very fast fulfillment --- Thanks Wayne --- your crew is doing an amazing job!
So, this is what I bought:
901-564-905-05-M100 rubber strip for rear of sunroof panel "panel"
911-564-191-00-M127 velvet strip, long one, for front --- I think this one is meant to go on the front of sunroof frame/opening
911-564-193-00-INT velvet strip, short one, for the back of the sunroof panel.
Now, when I removed the panel, this is what I saw:
1) no rubber strip was installed, but the panel did show that the strip was installed previously.Any chance that the strip is stuck inside the car frame?
2) front of sunroof frame/opening already has the long velvet strip --- in fairly good shape still
3) sunroof panel --- front had a velvet strip installed, but was falling apart, rubber inside the strip was falling out. I removed it from the roof panel and tossed it.
4) sunroof panel --- rear had velvet strip (short piece) installed, falling apart also.
Q: I've read that the roof panel front does not or should not need a velvet strip --- is this true? Would it hurt if I installed one anyway?
BTW, just for kicks, check out this delivery path via USPS Priority Mail. You wonder why the USPS is operating under loss/deficit each year --- and yours truly and all yourselves are helping to fund this deficit via our tax dollars....
https://tools.usps.com/go/TrackConfirmAction_input?qtc_tLabels1=940551020079 3355144739
http://forums.pelicanparts.com/uploa...1491695455.JPG
83_Silberpfeil 04-13-2017 05:04 PM
Bumping/reviving this thread, perhaps someone can chime in on sunroof seals...
my 83SC has...
1) long piece felt seal for the front of sunroof opening/frame
2) long piece felt seal for the front of sunroof panel --- falling apart, so I ripped it out
3) short piece felt seal for rear of sunroof panel
According to Wayne's book and also some posts here, #2 is not needed/used. But my car had it.
I am thinking of installing it back with new one for #2. Or should I leave it out and just go with 1 & 3 above??
Thanks!!
RSBob 04-13-2017 08:32 PM
#2 should attach to the back of the sunroof panel which will mate with #1 when closed. When I rehabbed all my seals, I did #3 as well thinking that any water which made it past 2 would be caught and diverted to the drains by 3. Don't know that as fact, but logically it seems to make sense. Never had water infiltration in the cabin due to the sunroof.
83_Silberpfeil 04-13-2017 11:06 PM
Thanks RSBob --- I tey try w all 1, 2, and 3 and see how it goes
83_Silberpfeil 04-14-2017 11:21 PM
made some progress tonight. Was a difficult evening, but persevered.
So, got the sunroof back in but had to re-install twice. After first time, I did not realize that the headliner piece on the sunroof panel needed run inside the rail. There goes 1 hr.
Problem 1:
Then, after I installed it, was able to crank it by hand. However, at full close, the rear of the panel did not want to rise all the way up/flush w roof of car. I can push it up and make it flush, but it won't go up by it self. I checked the cable holder and that pivot piece is set to the highest setting. What should I be looking to adjust?
Problem 2:
After I manually opened/closed the sunroof, I set the ignition on the setting just before engine crank, and operated the power sunroof switch. Heard the motor spin --- a very healthy loud sound, like the motor is running fast. but, not pulling the cable. However, the roof was not moving. Seems the motor is on neutral???
What to look for? Could it be the clutch piece?
Would appreciate some help from the board here. Thanks!
83_Silberpfeil 03-05-2018 02:58 PM
Cannae believe it's been almost 10 months since I left this project. Need to continue and finish it up.
Any advise on Problems 1 & 2 in post #22?
Thanks!
83_Silberpfeil 05-10-2025 09:21 AM
Resolved!
After over 8 years, I finally got the sunroof sorted out!
Resolution to Problem 1: The sunroof fully closes now, with a tight seal all around, and flush/even with the entire top of the car!
ISSUE: The segments of sunroof cable and tracks that run LEFT/RIGHT were stuck/clog'd w debris/gunk. The shop attached the cable segment to a drill and spun the cable to loosen the debris, then remove/clean.
I had cleaned only the cable/tracks that run FRONT/BACK.
Resolution to Problem 2: The power sunroof works now, full speed!
ISSUE: the transmission failed. It spun, but given any slight resistance, it fails to grab. Replaced part --- $$$$!!!
Good thing is the rubber clutch piece is still in tact, actually looking almost new!
Perhaps the transmission part could be taken apart and repaired? I don't know
Problem 1:
Problem 2:
jgurnari 05-15-2025 07:18 AM
what can I use to safely clean the grease off the full length of the cables?
REVerend 05-15-2025 07:41 AM
I haven’t tried it with the sunroof cables but have had very good luck with spray cans of Electric Contact cleaner. From what I understand it’s similar to brake cleaner, but not chlorinated and is safe on plastics.
jgurnari 05-15-2025 07:44 AM
thanks
