Who has done a custom gauge set up?
I am looking to add some additional gauges to my 911, but haven't really found any good ideas on how to go about it yet. I want to do something similar to the 935 in the picture below. I saw that pelican has delete plates available, but they're in metal. I was hoping to find or make something that would be more easily cut to allow custom sized gauges to fit into it.
Any ideas? http://forums.pelicanparts.com/uploa...1143059464.jpg |
You can do a lot with acrylic or lexan, cut, shape, paint:
http://forums.pelicanparts.com/uploa...1491741479.jpg |
watching.....
looking for ideas too. but also WHAT gauges I should consider. heavily modified 930 conversion in progress. CIS. almost have it torn down to the tub. recently pulled the windshield to get the dash out. |
If you are interested in monitoring your 930, some gauges you may want to consider include: AFR, Boost level, cylinder head temp, exhaust temp
Check out the turbo forum and search, I think we have some discussions on various AFR and boost monitors, for example. And someone has exhaust temp and cylinder temp monitors installed. Oh, knock sensors, too... |
Gauge manufacturers can make a gauge to fit your current hole sizes. I had a combination head temp and volt meter with a few warning lights made and used the hole where the useless VDO clock went. I wear a watch and there is another clock in the radio and on my cell phone which is velcro'd to the dash.
It was made by Westach, an aircraft instrument maker. $89 back about ten years ago. They offered one that would monitor all six cylinders but I opted for a single. Attached to the center #2 jug. A ring that sits on the spark plug. |
s5uewf,
yea I haunt the 930 forum too.... still a long way from this but always looking for more info/ideas. thanks. |
http://forums.pelicanparts.com/uploa...1491833047.jpg
My only custom gauge is adding a volt meter to the tach. It gets rid of the sill shift light that is rather annoying. And I did convert my temp gauge to have real numbers but that is just swapping the gauge and sender. Super easy to do. |
Some cool ideas in here. I'll have to go over to the 930 forum and check out what some of you guys have done.
| All times are GMT -8. The time now is 04:13 PM. |
