Slippery Slope Expert
Steam Driver's Avatar
Replacement Rear Speakers
Since I have the back panel out of my '82 SC I'm thinking I should replace the 35 year old speakers as a pre-emptive strike; that time can't be good for speaker cones.
Anyone know what a good direct replacement is? I'm not looking for premium sound (the car provides that) just a decent speaker. Doing a search of our host turned up nothing.
Old 04-01-2017, 07:34 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Speakers.
Rear parcel shelf fidelity is a bit difficult due to the lack of space
behind the speakers.
I replaced ours with the 3 way Pyramid 468GS.
The grids are close to the factory originals.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-01-2017, 10:30 AM
John W
I replaced mine a few years ago with Pioneer TS-A4674R. When I took the old ones out the rubber between the paper diaphragm and the case was partially dry rotted and gone. Sounds a whole lot better now!
Good luck,
John
89 3.2 Targa 123k miles
Old 04-01-2017, 12:23 PM
That's fond- just deglaze
I'm very pleased with the RetroSound R-463N 4" x 6" Replacement Speakers. Grills are a close match to stock and they fit perfectly (shallow depth).
Old 04-01-2017, 12:25 PM
DWeg1998's Avatar
I am happy with these- amazing how cheap speakers are now compared to the grill price-
https://www.amazon.com/gp/product/B014Z7IOGA/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00IK5EE2C/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Old 04-01-2017, 01:21 PM
Eng-o-neer
Tremelune's Avatar
Mm. The speakers in the rear shelf don't do much more than confuse the sound stage. I would simply unplug them. There's no money you could put there that wouldn't be better served in a different audio component (such as a modest amp or underseat sub).
Old 04-01-2017, 04:12 PM
Blaupunkt.
Old 04-01-2017, 08:11 PM
Yes, I think Blaupunkt. One thing that is "odd" (probably not though) is that this car has no speaker grilles, per se. Just holes in the rear shelf and the speakers are mounted on studs that are part of the shelf. I had noticed this before, and when I was at the Werks Reunion in Amelia Island I looked at a lot of 911's and SC's in particular. All of the ones I saw had external grilles like the ones pictured in this thread; not one had speakers mounted like mine. A couple of images follow; comments?
Shelf from the topside
Shelf from the inside
That foam strip at the top (in the image; back in the car) is about 2X2 inches, so speaker depth is limited.
Old 04-02-2017, 05:27 AM
911SC Tinkerer
merlinfe's Avatar
I replaced my front speakers with a set of Infinity Reference 6.5" Component speakers and maxed out the RMS wattage to them with an amp. I know this isn't the answer you're looking for, but the sound from the front of the car is so good now I don't need rear speakers.
I ended up disconnecting the rears completely and need to get back there to remove them.
If you have a grill-less rear parcel shelf you may be upset if you put grills in. The reflection from the grills on the back windshield glass is annoying sometimes.
-Steve.
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 04-02-2017, 06:14 AM
That is how the rear shelf looks on my 79 930. Maybe they ran out of the SC style and used a Turbo one. Or maybe there was a Leather upgrade Porsche uses this style with?
I also used Infinity Reference 4X6 speakers. If you have the rear shelf like the post I quoted. They did not fit the stock tabs perfectly. I had to use a large washer on two of the studs. If you wait for the new model switch on Crutchfield you can get them for 50-60% off. I think I paid $39.95 for the 4X6 rears. Better speakers are worth it. You don't need to go crazy to get decent sound.
Derrick
Old 04-02-2017, 06:39 AM
Missed Approach, have you had any issues with the R-463N speakers? The reason I ask is that I have them in hand (Crutchfield) and I noticed right off that they are 4 ohm impedance vs. the 8 ohms of the Blaupunkt speakers they are replacing.
Anyone, is this an issue? I know the end result may be just more volume, but I don't want to risk damaging the OEM radio (Blaupunkt Bamberg QTS). I think in some cases that could be an issue. Anyone chime in here, my own knowledge of electronics is limited.
Old 04-08-2017, 12:58 PM
Hi Steam Driver- unfortunately, I'm no longer running the Monterrey (I pulled it and replaced with a Blaupunkt CM148 Arizona and a Kenwood amp up front) I have Pioneer 6.5" TSG1645R 2-Ways for the front door speakers as well. The rears do sound nice, but not sure how they would pair with the existing Bamberg. This is a question for some of our more audio knowledgeable members- can anyone add insight on 4 ohm vs. 8 omhs? Sorry I can't be of more help!
Old 04-08-2017, 01:30 PM
Eng-o-neer
Tremelune's Avatar
What head unit is in the car? If it was designed for 4ohm speakers (most are), then it'll be fine with 4ohm or higher speakers.
Old 04-08-2017, 03:00 PM
Occasional User
Cook&Dunning's Avatar
Not a great pic, but these are Kicker speakers. Not expensive, but good response. Miles ahead of 1989 speakers. The grills are stock Porsche, they are secured with Velcro, as they do not snap on like with the originals
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 04-08-2017, 03:02 PM
My speakers have no visible grille, just holes in the shelf, so grille appearance isn't an issue. (See my pics a few posts back.)
More important, I think is the impedance issue. The original Blaupunkt speakers were 8 ohm, the prospective replacements - on hand) are 4. The Bamberg owners manual does not give a spec for speaker impedance, nor have I been able to find it on- line. I'm guessing that since the stock speakers were 8 ohms, that's what it was designed for. My question is will the radio itself be damaged by the lower impedance speakers?
Most speakers these days seem to be 4 ohm.
Old 04-08-2017, 04:38 PM
Eng-o-neer
Tremelune's Avatar
It's a bit of a gamble. It could be fine with it, just running a bit hotter. It could also run so hot that something fries.
Without specs, it's hard to be sure.
Old 04-09-2017, 09:48 AM
sugarwood's Avatar
Remove them and take them to a local Best Buy?
Also,
Which 4x6 rear speaker will fit OEM grille without mods?
1986 Bosch Icon Wipers coupe.
Old 04-09-2017, 10:38 AM
The problem isn't so much which will physically fit; there are lot of"work arounds" for that. The issue is finding an 8 ohm impedance. I'd say 95% of what's out there now are 4 ohm.
Old 04-09-2017, 02:43 PM
Administrator
Dmitry at Pelican Parts's Avatar
Not 100% sure if they have that size, but I would highly recommend MB Quart. Incredible sound and the prices have come down significantly.
Old 04-14-2017, 01:12 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
The 8 ohm speakers are connected in parallel, giving an effective 4Ω resistance.
The perforated leather is just like my 80SC Targa with special leather. The external speaker grills may have debuted with the 3.2, but I'm not sure
The depth is really the problem in this location. Note that the voice coils for the original Blaupunkt speakers are mounted ABOVE the speaker cone to minimize depth. I installed Alpine SPS-410 4 from Crutchfield using the mounting plates that came with. They fit and sound decent enough for me.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 04-15-2017, 02:23 PM
