Yellow Lens for 911 SC
So I want the yellow 'French' lens' on my '81 911SC...don't ask...just do(!)...legality aside...I have a pair of the Yellow Bosch Lens from Germany...Question is this, are the trim rings the only things that need to be changed?...think my rings are H1-go from thicker at top the thinner at bottom...is it H4 that I need ...and are the stock buckets that I have able to accommodate the lens...need paintable rings and what else...??..thanks!!
Old 04-09-2017, 12:22 PM
ROW '78 911 Targa
timmy2's Avatar
You need complete H4 lamp assemblies to change over to be able to use those lenses.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-09-2017, 01:45 PM
It's a really easy swap. Undo the screws on the trim ring, then unbolt the whole lamp assembly. I think it was four bolts around the edges. Then you can bolt in the new H4 assembly. Should be done rather quick. I had trouble getting the new trim ring to seat, and it still didn't take very long to do.
Jonathan
'79 Copper 911 SC
'88 White 911 Carrera- 98mm p/c with JE 8:1, Turbkraft EFI-T cam, Carrillo rods, Injector Dynamics 1050x, twin COP, AEM Infinity, twin Garrett GT2860rs's
Old 04-09-2017, 02:02 PM
Formerly known as Syzygy
Canada Kev's Avatar
The more difficult part is changing out the existing clear lenses for new yellow lenses of the H4 assembly. It is a little fiddly taking out the little spring clips and then replacing them. Wear safety glasses as they an fly out unexpectedly.
Great car colour, too, BTW!
Kevin
Old 04-09-2017, 02:38 PM
RETIRED
Joe Bob's Avatar
Yellow stained glass window tint, from Krylon. So when the POPO busts ya, you can single edge blade it off.
$7.99 USD in a rattle can. Tell your friends, have a lottery on which lasts longer, the paint or the time until you HAVE to take it off....%^)
2012 ML350 3.0 Turbo Diesel
Old 04-09-2017, 06:21 PM
Thank you guys!!
Old 04-10-2017, 08:32 AM
