disband
juanbenae's Avatar
weber linkage
moving a CIS 3.ol to carbs and was hoping someone might look over my mock up prior to reinstalling the motor in the car. I realize there will be significant adjustment required once the tranny bell crank throw is revealed when the motor is seated. lost the CIS bell crank mount on the motor and ordered a manifold shaft bell crank from PMO that is installed. ive cut the tin, but need to do more without hacking the S out of it, but would like to cut it before the motor goes back in.
rate my mock up
have I orientated the tranny bell crank correctly? I'm pretty sure ive got the PMO piece correct in direction, but still wondering if I used the correct of the two slots on the carb rod side??
t
Old 04-11-2017, 05:00 PM
