-   -   14 pin connector from 964 engine (http://forums.pelicanparts.com/porsche-911-technical-forum/952937-14-pin-connector-964-engine.html)
smokintr6 04-11-2017 10:53 AM
Does anyone have the full pin out for the 14 pin connector coming from a 964 3.6?
I need to connect it to the engine bay of a mid year car that has had some wiring modifications before. I'm only concerned about the engine side... should be blower wiring, alternator signal, oil pressure and temp etc.
I have a 964 factory manual and i have the pin out for the DME connector, but not for the chassis harness.
Thanks!
Don Nguyen 04-11-2017 07:06 PM
Bump, because I am actually trying to look for the exact info as well!
Busta Rib 04-11-2017 08:09 PM
I don't have the full pin-out for the 964 engine but I just did a 3.6 conversion into my 77 and mapped out what needs to be converted on the engine-side 14-pin if this helps:
http://forums.pelicanparts.com/porsche-911-technical-forum/871450-busta-ribs-tale-1977-911s-widebody-5.html#post9442163
