smokintr6's Avatar
Send a message via AIM to smokintr6
14 pin connector from 964 engine
Does anyone have the full pin out for the 14 pin connector coming from a 964 3.6?
I need to connect it to the engine bay of a mid year car that has had some wiring modifications before. I'm only concerned about the engine side... should be blower wiring, alternator signal, oil pressure and temp etc.
I have a 964 factory manual and i have the pin out for the DME connector, but not for the chassis harness.
Thanks!
Old 04-11-2017, 10:53 AM
Bump, because I am actually trying to look for the exact info as well!
Old 04-11-2017, 07:06 PM
GOM (Grumpy Old Man)
Busta Rib's Avatar
I don't have the full pin-out for the 964 engine but I just did a 3.6 conversion into my 77 and mapped out what needs to be converted on the engine-side 14-pin if this helps:
Busta Rib's Tale of a 1977 911S Widebody
Instagram: @3pedalposse
Old 04-11-2017, 08:09 PM
