Engine/Transmission Mounts
I realized after the order was shipped I added only 2 mounts. Given I wont be placing another order for a bit if you had two replace only the transmission or the engine mounts which would you replace?
1986 Meteor Grey Carrera - We'll meet again in Valhalla. |
More Likeable IRL
id replace the motor side 1st as the transmission mount are important for shift quality they are significantly easier to install with the motor & tranny installed if you were to do it later.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
911SC Tinkerer
Is the car all original mount wise? I'd actually replace the transmission side if you're having any kind of shifting issues.
I used solid mounts for the transmission and semi-solid for the engine. HUGE improvement. Might be worth it to just order what you need and do it all at once. It'll save you time in the long run. -Steve.
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
911SC Tinkerer
It's true that the areas are separate. My rear engine motor mount bar snapped and I had to replace it, which meant a partial engine drop, which meant I was going to raise car and put it on stands anyway. You get the idea from there. Good luck, let us know if you need help.
-Steve
Member 911 Anonymous
If the mount you got is the Stock "SOFT" mounts put it on the engine side. Then order the Cabriolet "harder" Sport mounts for the gear box.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
