While you are running the lines I would really recommend you consider the Elephant Universal Crossover Pipe as it will work with any variation of exhaust you can come up with. (For 86 and earlier cars.)
It is really nice to only think about the exhaust when you are changing the exhaust! (If you want to use the Universal Crossover Pipe on an 87 to 89 G50 car talk to me about how to mod the trans so it will fit.) |
Hi Len,
I agree, I did try a lot of options and there was no way my hose was working, didn't think of raising up the wheel well though :) however clearance there is a major issue for me with 17x11 and 315 tyres. Tried a few places to bend the pipe and couldn't find anyone with the correct size, must be an odd size for NZ. |
Brent - These are all M30 hose & fittings. Here is what I make up for a Hi-Rise Hose layout........... http://forums.pelicanparts.com/uploa...1493897223.jpg I know its a long way to NZ so shipping the assemblies would be costly. I could send just the custom Z bend and other fittings if you can find a local Cohline dealer to assemble the hose. Len :) PS - Guess I should point out these are high clearance hoses in the fenderwell to allow FAT tires, and not a crossover to clear the exhaust. Len |
Consider replacing the S line while you are at it. They can and will fail, ask me how I know....%^(
BoxterGT your PM box is full so I couldn't contact you that way. But I'm very interested in the oil Crossover lines that you are showing above. Please contact me at 925-457-two-seven-seven-five, or PM me. Thanks, Brian
| All times are GMT -8. The time now is 11:31 PM. |
