-   -   69' Brembo caliper upgrade with SC rotors (http://forums.pelicanparts.com/porsche-911-technical-forum/953847-69-brembo-caliper-upgrade-sc-rotors.html)
Brett Voigt 04-19-2017 09:04 AM
I recently purchased a set of Brembos off an 80's Alfa GTV6. They have the 3" spacing to fit the strut assembly of my 69'. Paired to it are some SC rotors and I could not be happier with the bolt in fit. The stock M caliper only has one slot for the banjo bolt to fit in, whereas this has 2 bleeder valve. Does anyone know which valve I should remove to fit the banjo bolt? The top vs the middle, or if it even matters? http://forums.pelicanparts.com/uploa...1492617831.JPG
TRE Cup 04-19-2017 10:52 AM
Put your admission port on the lower location. Air needs to be bled off the top of the caliper
Brett Voigt 04-19-2017 02:08 PM
Makes sense. Thank you.
