-   -   Conversion issue ! (http://forums.pelicanparts.com/porsche-911-technical-forum/954046-conversion-issue.html)
ppetion 04-20-2017 06:33 PM
Conversion issue !
70 conversion with 3.2L - 915 transmission
I drove the car for the first time today. There was a vibration noise under the rear seat , at first I was thinking something was wrong with the transaxle , upon inspection I found that the transmission is touching the tub under the rear seat ( see pics).
Anyone familiar with the issue ?
I am thinking of putting a washer / shim to drop the transmission a bit ,
As always , Your input is appreciated. http://forums.pelicanparts.com/uploa...1492738374.JPG
esses62 04-20-2017 06:48 PM
Paul catastrophic failure is imminent I suggest just handing me the keys I'll sort it out
ppetion 04-20-2017 07:04 PM
Scott ,
You got it !
BTW I have those tires , they were slightly to wide . I'll drop them off next week .
Are you hersheying ?
Jack Stands 04-21-2017 08:41 AM
Since it's a simple and reversible change, I'd try to shim the transmission mount first to gain some clearance. Certainly checking for tire clearance makes sense as well, but it sounds like the transmission rubbing may well be the culprit.
RD911T 04-21-2017 09:11 AM
When putting a 915 in an earlier chassis that didn't originally have a 915, the chassis has to be clearanced to allow the nose of the 915 to fit. This can be done with a BFH or by cutting and welding. I would not shim the transmission.
Walt Fricke 04-21-2017 04:35 PM
+1 what RD said. Not hard to do, not a large area, all as I recall on the left side, and you won't notice it inside the car as you don't need much.
ppetion 04-21-2017 05:17 PM
Thanks guys, after reading some threads here , I took care of that today with a hammer.
